1 - 13 of 13 Posts
I am having front axle issues on my VT800 1988. We are currently on a trip and stopped right now. I am desperate to fine a picture of the front axle at the fork area on both sides.
If you have a good, clear pictures please post them.
Thanks!!
Discussion Starter · #4 ·
Tried, its not helping much. Somehow the two nuts at the bottom end of the right side fork came loose and the bottom half moon bracket that mounts to the fork to hold the axle had slidden to the outside edge of the axle. I dont think the fork is to be out that far.... I thought it was to be in more on the axle bushing. I'll have to see someone's picture to know for sure. Wish there was a honda shop nearby.
Be easier if you post a pic of what you are seening. Then we could say what needs to be done. Is the axel loose???????
Loosen the fork caps and tighten the axle, retighten fork caps. That looks like the axel is working its way out. You dont need a HONDA shop and motorcycle shop and most auto repair shops, will do in this case.
1 - 13 of 13 Posts
