Just installed a Thunder Manufacturing air kit on 1998 ACE 750. Stage 3: 134/138 jets, needles on groove 4. Did not install new pilots (did not come with the kit). Vance and Hines Cruzers for exhaust.
Problem:
The things runs great! But....when I am running at highway speeds and let off the throttle a little, and then re-apply the throttle, there is a very slight hesitation, then grabs and levels out. There is the same hesitation if I am getting on the throttle hard while going through the gears at the point of re-applying the throttle in the next higher gear.
Deceleration seems to be fine at 3 turns out on the screws.
Also, the mpg's dropped substantially. Haven't been able to check it accurately, but probably around 10 mpg less?
Any thoughts?
Thanks
Bob
Problem:
Any thoughts?
Thanks
Bob
