Hi all Well second post this time I have a question. So have a bad oil leak. Cant find it. I actually have two leaks but found the second one. Leak I cant find and is the one that is stumping me. It seams to be under just right of the oil filter housing. Dripping down I think it is behind the water pump. I think it is the water pump. There is a hose going to the radiator"assuming" I cant see were it is coming from. The second leek is the cam plug back left. All the manuals say remove the motor to replace it But im going to try to fix in place. I have removed the plug. It is cracked and bridle SO getting a new one. Going to insert it half way. then stuff it with black silicon, shove it in. Let it cure for 2 days and See what happens. What you all think Thanks for the help
Shadow 2000 1100 C
You can see by the arrows were it leaking.
Shadow 2000 1100 C
