1 - 10 of 10 Posts
I have a 2009 aero 750 and thinking about doing the hole saw mod. Most videos I've seen use a 2" saw. I was wondering if I should use a 2" or go 1 3/4". My thought is if I use a smaller saw It would leave a nice ring to tack weld the resonater back on if needed. What do you guys think?
If it turns out like mine, you lose enough metal with the hole saw cut that welding the resonater back in would not be easy.
I did the mod to my 09 Spirit and the sound is pretty nice for the money. Today I switched bikes with my riding buddy for a few miles. Got to hear how it sounds from that perspective and it sounds good, especially when you are getting on it a bit.
I used a 1-7/8 bit, no lip was left for re-attaching.
I put mine back in using JBWeld. It was a pain to hold steady while it setup, but it is possible.
I didn't use a hole saw... I used a sawzall and cut straight through right against the back of the muffler and right through the outer weld. I had the two halves welded back together and can easily have it welded back in. One piece fell in, the other fell out, and I used my magnet to get the two inner pieces out. Took less than three minutes, TOTAL, to do both sides. My T sounds GREAT, and I'm tickled with it!!
a smaller hole would make it more easy for you to have them welded back in yes...
an make it more clean look when ,and if you have them re welded
Paul can you post a pic of how yours turned out? I was considering something similar.
Yes, after I get back home from vacation (Saturday afternoon or Sunday)... don't have tools to take the chrome tips off at my mom's house. If I forget please shoot me a personal message to remind me!
(This is part of a copy of what I posted in another thread about the holesaw mod)
I originally did my mini holesaw mod trick as described below in #1, but then eventually did it as per #2. In either mod, you will NOT have to do any changes to the carby jetting.
But if you do the Airbox Mod and put a K&N filter in there, well you may possible have to look at the jetting, but not always. But futunately for me I don't have to worry about jetting as mine is EFI...
Doing either of these mods, and if you have the tools on hand it will only take about 10-15mins doing it yourself.
These are two ways you can do the Holesaw mod to the original exhaust.
Keeping the Original Look
#1. Keeping the original look, you can just drill the end cap of the 1" pipe (Img #1) with a 15/16" drill (or use a small holesaw if you can't find a drill that large) or maybe use a 1/2" drill and drill a few holes into the resonator end cap. I went one step further and drilled a 1/2" hole into the rear baffle, sounded very nice...
The Full Resonator Removal
#2. Or do the full holesaw mod (which I eventually did) which removes the resonator. But I would suggest that you use a 1-3/4" holes saw as this will leave a narrow piece of metal around the circumference of the muffler (Img #2) so if you at any stage wanted to replace the resonators or for what ever reason, you can as you still have a metal ring to weld them back into place...
Also If you want to go a little further the get a more distinct sound, you can also block of or restrict the cross over tube...
Hint: Before drilling with the holesaw, knock a piece of wood into the 1" pipe, drill a small hole into the centre of the wood as a guide and then when you use the holesaw, it will centralize the cut in the muffler leaving an equal piece of metal around the end of the muffler (Img #2)...
Safety Hint: Also make sure it's in 1st gear and chock the wheels to stop it rolling forward as when your drilling it is possible to push the bike of the stand.
#1... I did this first as it kept the original look of the pipes, but louder sounding more like a V-Twin but not over the top...
This image has been resized. Click this bar to view the full image.
#2...
I did this after having the first mod for about 6 months and it was louder, but again, not over the top...
Sound Clip Link to this Mod...
1 - 10 of 10 Posts
