1 - 2 of 2 Posts
I have this Honda shadow 750 it's giving a fuel line problem y send buy relay fuse and fuel pump i connect it the correct way but know the pump it's not pumping so I try the old pump and it works but it is pumping to hard not the correct amount of fuel it's to much so I know that the relay it's working ,,I desconect the relay and after a while it's cranks rite then when the carburator fuel done it shut down can uno guys give me an advice thanks appreciate
2001 Valkyrie I/S
Welcome Henry, is the old pump the original? It almost sounds like it has too much pressure, it should only have about 2 psi.
1 - 2 of 2 Posts
