1 - 9 of 9 Posts
My son's 2003 Shadow 600 has been giving us problems. On a totally random basis, the battery will be to weak to start the bike. Jump or roll start it and it'll run fine for a week or two. Then sometimes after being parked overnight or even after a 20 minute ride, same problem.
I had the battery load tested and it appears to be OK. So today i tested the rec/reg. Six different combinations as per YouTube. 6 with equal readings, 5 with zero and one indicating backward flow.
YEAH, Problem Solved. But then I went on line - rec/reg range from $30 to over $100.
Any suggestions????
Thanks in advance.
Tom
2002, Shadow Spirit 1100
I recommend the oem part from Partzilla. How old is the one that failed?
'97 Spirit 1100 - Chandler, AZ
I personally wouldn't trust the $30 ones. I'd probably go oem for a 600.
I tend to go for overkill and mounted the Shindengen SH847 under my 1100, Rock steady voltage... tight fit though, probably 3x larger than the 600 one.
Agree w/oldguy... stay away from the cheapie $30 items on e-Bay. Buy OEM or a quality aftermarket item like an ElectroSport: www.electrosport.com/collections/street-motorcycles-honda-2003-vt600c-vt600cd-shadow-vlx
Best to do it once and do it right!
I'm guessing it's the original 2003. We bought the bike in 2018 with 9000 miles on it.
The stock R/R lasted 15 years and 38,000km, it had had enough, the stator and the 3 yellow wires were perfect though and still are. Now I've mentioned it., maybe it's a Schrodinger's Cat and I may or may not be fscked any time now. )-:
I went for a twenty odd dollar regulator, it had a 90 day warranty, it lasted 92 days. You can say what you want, but that's precision quality control! |-:
I then bought an ElectroSport HD it was a bit of a pain I had to drill new holes for my 750 ACE, it was kinda expensive for me due to bad timing, it is six years now, still works like day 1. (-:
I'd probably go to RoadsterCycle or Ignitech these days, no reason other than to try something else. (-;
'83 VT750C
Could you mount one of those cheap little digital voltmeters for power sports equipment on the bike and try monitoring that for voltages during rides and starts?
Discussion Starter · #9 ·
Decision made. Someone recommended DB Electrical. They're an American Company in Kingsport, TN.
Funny thing is, I went to their website and they showed the one I needed as "out of stock" but their Amazon store had it.
Thanks to all for their advice.
Reactions: kesanders
1 - 9 of 9 Posts
