1 - 4 of 4 Posts
I am trying to remove the pedal assembly from my 02 750 ACE.
I have it all apart ( finally after I got that freakin cotterpin out :evil: )
and the last thing I need to diss-assemble to remove the enitre assemble is the Brake light switch....
How is that done?
I see there is a plastic type of washer that sort of mates up to the mounting plate. It doesn't look like it will take a wrench, so do I just loosen it by hand?
Any advice or tips would be greatly appreciated 8)
for reference I am trying to remove item # 6
http://houseofmotorcycles.bikebandit.com/partsbandit/oem_schematic_view~schem_dept_id~383783~section_dept_id~1~section_dept_name~OEM+(Stock)+Parts~dept_type_id~2~model_dept_year~2002~model_dept_mfr~Honda~model_dept_id~375153~model_dept_name~VT750CDA+(SHADOW+ACE+DELUXE-BLACK)).asp
I don't know on your bike specifically but I would think that once the #7 spring is unhooked from the switch, the switch should pull right out of it's mounting hole. The knurled ring is just to adjust the switch out and in.
According to the schematic and looking at my bike - it looks to me like just unplug it, remove the pull-spring and unscrew it (adjustment screw) and it should come right out.
Discussion Starter #4
You where bang on, as soon as the spring was disconnected it came out.....took a bit, but it came out pretty easliy.
Thanks guys
1 - 4 of 4 Posts
