1 - 5 of 5 Posts
I'm far away from home so I can't look at my owners manual. I trying to put a bunch of chrome on my Shadow Spirit VT1100, but I reached a problem and can't figure out how to remove the bracket or lens to the headlight, to install a chrome shield piece that over laps for my bike. If anyone know how, it would be greatly appreciated. I'm sorry for this stupid question.
Assuming it's like the 750 Spirit:
If you're talking about the trim ring that holds the headlight assembly into the shell (as if you were replacing the bulb), look on the bottom at about the 4:00 o'clock and 8:00 o'clock positions and you will see two small bolts. Use an 8mm wrench and remove them. Pull out and down on the bottom of the ring. The little bolts go through some spacers that you can see, which also come out with the bolts, so be careful you don't lose them. (In other words don't do this over the grass.)
Rick
I was a little slow on the draw :D
Discussion Starter #5
thank you so much, I got the trim on. Your pic helped a lot. Looks very nice with the new chrome
1 - 5 of 5 Posts
