1 - 14 of 14 Posts
I have a 2009 Honda shadow 750 that started running on like 2 cylinders under load. Now it's gotten a lot worse, it seems like at times it does run on all cylinders but I really don't trust it to go anywhere. I replaced the plugs and it didn't help. So now I ordered a new air filter but I'm really thinking it's one of my coils. When I changed the oil I overfilled it but I got it where it supposed to be now, I had probably a half a cup in my airbox. I really can't think of anything else so any information would help
Hey MKP,
Just for information sharing: Your bike is a 2009 Honda Shadow VT750. The VT means it is a V-twin (that means 2 cylinders). I'm guessing that because it has 4 spark plugs and 4 spark plug wires you may think it is a 4 cylinder???
1998 750 ACE
That Excess Oil MAY have clogged the air filter???
Good Luck,
Dennis
Our Gurus will chime in when they get back from their Sunday RIDE
Or Fathers Day Dinners
What makes you think its ignition related? The most common issue with Shadows is dirty carbs as the electrical/ignition is pretty bullet proof however one flaw that needs to be fixed regardless, is the "3 yellow wire" connection.
Discussion Starter · #9 ·
I'm just guessing because it's never really sat without being run, it ran great this spring. What is this 3 yellow wire connection?
3 yellow wires on the stater to regulator harness.
It overheats and looses contact, and the battery charge rate goes down.
Maybe under the seat on your bike.
You don't want this=
Motor vehicle Electrical wiring Gas Auto part Automotive exterior
Reactions: mkpike24
Discussion Starter · #11 ·
What does it do when revving it in Neutral? (No load.)
Thank you, I'll check
I will definitely check it out
'83 VT750C; ‘21 SV650A
I’m sorry I broke your Neutral… 😉 That does shift things towards it possibly being electrical. Just eliminate one thing at a time until you find the culprit.
Discussion Starter · #13 ·
So my details were a little unclear, process of elimination. I knew it wasn't much, it's a Honda!
Good Luck,
Dennis
You were excactly right!!!!!! It was the air filter, apparently it plugged up my filter by putting too much oil. Running awesome again
1 - 14 of 14 Posts
