1 - 10 of 10 Posts
This is the condition the fuel filter was in. Oh and I’m pretty sure that it was on backwards from the previous owner. Very little mechanical knowledge kinda learning as I go. Any tips or pointers are much appreciated!
295880
295879
The filter sure did it's job even if it was backward.
Play it by ear.
Put in some Seafoam, ride it a while and see if it needs the carb done.
No use opening a can of worms if it starts and runs well every time.
Discussion Starter · #3 ·
Play it by ear.
It starts and idles for a few but chokes out after a couple of minutes or when any throttle is given. Last fill up I put a little file system cleaner in it. Can I add sea foam with the cleaner that I put in already?
'97 Shadow Spirit 1100 - Chandler, AZ
VLX - I'd burn through the current tank of fuel, rather than mixing the Sea Foam with another additive. The current cleaner you added will continue to work on the deposits, so no harm in waiting. Keep an eye on that new filter, as the cleaner will continue to loosen varnish and sediment. You may need to change it several times until it starts staying clean for longer periods of time. ⌛
Keep it simple stupid 😂 I found the problem runs like a hoss now. It was the hose from pump to carb was a little kinked choking it out.
Discussion Starter · #6 ·
I am planning on it thanks for the heads up! I was surprised to find that the filter was only $5 lol
2003 VT1100C Spirit
You may have more mechanical ability than you give yourself credit for. A kinked fuel line is an often overlooked 'carburetor' issue that has stumped plenty of experienced shade tree mechanics.
'83 VT750C
Besides, you’re always safe looking at the carburetors! 😉
From what I can tell, the only difference in the filter is, installed properly, a bit of fuel comes inside the filter and goes to a larger piece outside. So, going backwards, it’s conceivable the engine could draw fuel faster than the filter could… filter, but I’d doubt it. That would take quite a bit of gas!
This is the condition the fuel filter was in. Oh and I’m pretty sure that it was on backwards from the previous owner. Very little mechanical knowledge kinda learning as I go. Any tips or pointers are much appreciated! View attachment 295880
TOO Many people go digging into their bikes Way Too early!
Run some SeaFoam.
And, not just a couple of ounces.
Pour half a can in there, it won`t hurt, it`s a petroleum product !!!!!!!
If that doesn`t help, try another half of can, and another.
RIDE!
295943
Discussion Starter · #10 ·
Run some SeaFoam.
RIDE!
I am starting to notice that as a common go to for myself each time something happens and it’s not lol. Thanks for the advice good sir! Next weekend when I ride I’ll add some to a fresh tank and smoke everyone out 🤣
1 - 10 of 10 Posts
