I have a 1999 Honda Shadow vt600c
When I start the bike, it almost never starts on the first try. And usually when it does it will sputter out. It's usually about 95 or so degrees outside, I don't know if that matters.
Then I put it in first and begin releasing the clutch and giving it fuel and either it goes, but very hesitantly, or it seems to not get much fuel and can either sputter a bit or it just WONT go. (Sometimes it just stalls out altogether.) So I turn the throttle more and it will sputter, then TAKE OFF as if it finally got fuel. It does this mostly in first gear, sometimes in second, very rarely in third, and not at all in high speeds.
It's been having this problem since day one, so I cleaned the carb, checked the idle, air/fuel mixture, poured seafoam in the tank, spark plugs and that seemed t600o fix it. Then I let it sit overnight and the problem has returned. I am not a mechanic by far and I've got a bit of help from my friend who is pretty knowledgeable. He's going to work on it next week for me (and give it a pretty little paint job) and I was wondering what you'd suggest I do and what you feel the problem could be so I could have him check those things out.
