Hi all you motorcycle riders,
Long time browser, first time poster. I have a 95 vlx 600. The front cylinder is not firing. I have good spark. There is fresh, new fuel on my new plugs. I did a compression test which came back around 50 psi. I removed the valve cover and checked the valve clearances, which was within spec (.006 in / .008 ex). I did another compression test for kicks, which came out at about 130 psi. I then did another test to confirm the earlier one was not a mis-meter and it came back at about 50 psi. I'm stumped! :neutral: What is the next direction I should go?
Thank you for your help. :mrgreen:
