1 - 5 of 5 Posts
Hello all. I'm a newbe to this forum but have been a member of the GL1800riders.com forum for several years. My wife has a 2002 750 ACE Shadow. Due to various reasons, it has been setting in our driveway for the last 2 years without being ridden or even started. We failed to drain the gas tank or carbs. I did put StaBil in the gas, but that was before I knew that it didn't help with the ethanol in the gas. Anyway we have sold the bike. When I went out to start it, the battery was dead even though it had been on a battery tender all that time. After new battery it would start but not run very well. I bought some sea foam and added to the gas. I started it and let it idle hoping the sea foam would clean out the carbs enough to sell the bike. After about 5 minutes at idle, I noticed gas pouring out from somewhere under the gas tank and around the carbs. It wasn't the gas valve or the vent tube. When I killed the engine, the gas leak stopped. I started the engine again, and the gas leaked again.
When I pulled the tank I can't see any obvious source for the leak. I'm not much of a mechanic so I don't relish the thought of pulling the carbs for a cleaning. I'm hoping someone out there has seen this problem or can give me some quidance to a repair.
Thanks in advance for any help.
Joe in Modesto
Welcome Joe. I am no mechanic at all, but my new bike had the same problem when I bought it. Turns out needed a carb cleaning and the floats were stuck. After a good cleaning the problem was solved. Don't know if that is what your trouble is, but definitely worth looking into.
Discussion Starter #3
Thanks CJ7. I was hoping the sea foam would loosen everything up. Wen I look at all the hoses and other fittings to the twin carbs, I get dizzy. It has been sitting for about a week since I first had the problem so maybe I'll go back and try it again and see if it has had time to break up all the gunk.
Joe in Modesto
Sometimes stuck floats can be joggled loose by rapping on the side of the carb's float bowls with the handle of a screwdriver. Not a permanent fix by any means, but might get them moving again.
1 - 5 of 5 Posts
