1 - 5 of 5 Posts
Replaced tail light, brake lights, headlight, and turn signal, and relay (in wiring behind headlight) and everything works as it should except... The little green indicator on the front fork. No clicking any more either.
Needless to say I always have a blinker on because I never remember to turn it off lol
Anyway to add the sound or fix the green indicator light (worked with halogens) ? Is it a thing to add an auto shutoff to bikes that don't have one? My 1982 seca xj650 had an auto shutoff!
2011 shadow aero 750
Ben- PHX , AZ
2001 Valkyrie I/S
You won't have any clicking if you changed to a digital flasher. The green indicator your speaking about is it the turn signal indicator light? What exactly is or isn't it doing, we need a little better explanation.
2001 Valkyrie I/S
I would pull the bulb and see if it's burnt out. Did you install a diode kit to keep any current crossover from occuring?
Discussion Starter #5
Bulb is good. Not sure what the rest of that is. I'll do some research and learn a bit about it. If you have a link to a part that would fit , that's be helpful.
Thanks.
1 - 5 of 5 Posts
