1 - 14 of 14 Posts
I just bought an '84 VT700 and need to do some major work on it, part of which is on the lighting. I figure I might as well upgrade to LED's on the turn signals and rear brake, but I'm not well versed in the conversion. Are there plug/play set ups available?
I found the blinkers here: http://www.harrisonspecialties.com/...t_Code=Chrome_Teardrop_Amber&Category_Code=TD
Still looking for the tail light if anyone has any sources...
Sent from my Motorcycle iPhone app
You’d be hard pressed to find a whole new brake light that will fit/look right off the shelf. But an easy fix would be to convert yours with a simple LED bulb.
I went with the classic (universal) Lucas style on my Shadow. On the little bike I use an LED Cateye (universal).
See Attach:
Depends on the "look" you’re going for. ;-)
Discussion Starter · #7 ·
See Attach:
Im going for a minimalistic look, more bike and less light, but I still want to be seen- hence the LED. More light in a smaller package.
<meta name="keywords" content="24 LED Motorcycle tail marker turn signal indicator blinker trailer lights chrome plated teadrop Harrison Specialties" /> <meta name="description" content="Chrome Plated Teardrop LED Light set with Amber LEDs for motorc
Just not sure how to wire them into the system...
Essentially you need to take one wire from the indicator on the dash and run it to ground. The other one connects to a diode and splits into two wires and connects to the signals.
The kit comes with instructions or you can look on the website. I posted a step by step here somewhere.
Discussion Starter · #12 ·
Awesome. What about the tail light? Any advice? Not sure exactly what style, but it'll definitely be LED. on that note, know of any good places to find custom led brake lights?
Brake light makes no difference since it is a simple circuit. you can just replace the lights with LEDs. I maintained all stock housings and just replaced the lamps.
I suggest SMD Leds over the LED lights pictured above since they are brighter. Different ones can be found at superbrightleds.com. I get all my LEDs from these guys as their prices are good as is their quality.
1 - 14 of 14 Posts
