Can anybody point me to a module that I can wire into my "Key On Hot" wiring that will give a small dinging/beeping sound when the key is turned on ( like the cars have if you leave the key in the ignition):roll:
It does NOT have to go off when the engine starts and it can remain beeping while engine is running ...
WHY you ask??? .. Because I need a fail safe to alert me that I have left the key in the "On" position ( which means my lights are still on and sucking my battery dry:-
-( ) while I am flapping my gums to whomever ... after I kill the engine by with the kickstand or thumb switch ....
Happened to me twice in the past year and sad to say the embasrrasment is apparently not enough for teach me a lesson to turn the key to off ....
