I lost my keys to my 94 shadow 1100. How can I go about getting the key code to get new keys made? I called the dealer and he said look on the back of the ignition but I don't see anything there.
There is a code either on the side or back of the ignition. You may have to take it off to find it. I believe it is a 5 or 6 digit code. You use take the last 3 digits of that code to your dealer and they can cut a new key.HOMER PIMPSON said:I lost my keys to my 94 shadow 1100. How can I go about getting the key code to get new keys made? I called the dealer and he said look on the back of the ignition but I don't see anything there.![]()
I believe you will have to take the cover off...but you don't have to take the ignition completely apart though. Remove it from the frame and remove any "loose" covers that are held on by the bolts.HOMER PIMPSON said:Thats what I thought but I didn't see a code on the ignition. Is it very small or imprinted into the platic cover on the back? Or do I need to take that cover off and look on thye inside?
I bought my Spirit 1100 used, so I don't have the key codes on paper. I noticed a code similar to the codes adlowe lists. Is the key code stamped on the "original" keys?adlowe said:The key code will be something like "A27" or "B53" and a Honda motorcycle dealer can, indeed, cut a key from the code; one near me charges $9 to do it. (Don't worry, I made up the examples.)
You don't need a key code to have your key or keys duplicated, just take the key you have into a locksmith and he can make copies for ya.jfusa said:I bought my Spirit 1100 used, so I don't have the key codes on paper. I noticed a code similar to the codes adlowe lists. Is the key code stamped on the "original" keys?adlowe said:The key code will be something like "A27" or "B53" and a Honda motorcycle dealer can, indeed, cut a key from the code; one near me charges $9 to do it. (Don't worry, I made up the examples.)
Thanks,
Jim
2001 Spirit 1100
Go to a different dealer. They can make the key from the codes if they have the key cutting tool and the book to do it. I had 3 keys made from the code for a total of $20 at my local dealer.HOMER PIMPSON said:I think I found the code it is a##. Stamped in the metal on the side of the ignition. I called the local honda dealer but he was no help. When I read him what I thought was the key code he said I don't know. So tommorow I am going to a lock smith with the code I found and hopefully it is the key code. $15 is alot better than the $90 they want to cut a key without the code.
Yes, it is the code stamped on the "original" keys. That is, in fact, the easiest place to find it -- provided you have the original keys. And you should write the number down somewhere handy in your wallet (like on the registration) should you ever need it.I bought my Spirit 1100 used, so I don't have the key codes on paper. I noticed a code similar to the codes adlowe lists. Is the key code stamped on the "original" keys?
