G
Guest
·I'm having an 84 magna rebuilt for my son. What things would you definitely include-in the rebuild? So far the frame is going to be powder coated, 83 carbs will be used, wheels from an 83 will be used, the forks shortened, the frame gusseted, stainless nut, bolt, and screw kit. What else do you suggest, considering my main goal is to make a scoot that is responsive, safe, dependable, and that will have longevity? I remember hearing of hard pistons that cause less friction. Oh, I'm also getting the DRP oiler mod. kit put on it. Mr. D is doing the job. I don't want to get it home and find something that should have been done that was not done. Can you give me a list of what you would have done, keeping in mind I am disabled and limited when it comes to turning a wrench. I would like to just look at the main engine components and say "this thing was done right. PS the guy doing the rebuild will attempt to set a new world record in the 750CC class at Bonneville Salt Flats, I believe this coming august.
3 mag
3 mag
