ok..so I'm sittin' here and realized I haven't updated this build on this forum. Here's what I've been doing with it in the last year.
Kind of a long read..but at least there's lot's of pics!!!
This begins my build thread on my latest project bike, an '82 750 Maxim. I picked it up for about $400. Flat front tire, wiring at the headlight all unplugged. The guy told me the bike had been sitting for about a year.He got the bike from a friend who got the bike from some guy who ran it off the road into some heavy brush. Supposedly it ran after the crash and that owner had replaced the front forks. Clutch cable is gone, brakes need a new MC and lever. The guy I bought it from said he couldn't figure out the wiring to get it started....
Fast forward 2 months. Got the wiring all hooked up and with the help of forum members on xjbikes I got my starter circuit bugs worked out. PO had swapped the starter relays.
Once I got that straightened out I took my carbs off and cleaned out the bowls. Pretty ugly. Everything was gunked up so I know this winter I'll be rebuilding those.I just gave them a quickie clean job and slapped 'em back on the bike. Put in some gas and hit the starter. She sputtered but wouldn't start. Used some starter fluid in and she fired right up. She had trouble running but then the rpms kicked up to about 4k and stayed there. I used the key as a governor to keep her running but not screamin'
So, at least I know she runs. Now I can start my build knowing that it will at least RUN when I'm done 8O
So here's the plan so far:
Shorten the rear suspension.
Drop the seat area of the frame.
Move the controls forward.
Fabricate a solo style seat.
New rear fender.Not sure if it will be bobbed yet....
new front fender
Still tossing around the idea of a bolt on type chopper front end, nothing radical, 5-9 deg rake with 4inch over down tubes. Pocketbook will have the final say on that one though.
Drag style bars or something close to that.
Want to upgrade the dash to something simpler/cleaner.
Probably change/modify the headlight assm as well.
And will fabricate an exhaust system for it.
Good thing I have all winter and spring to do all that 8O
SOME PICS! Remember ...WITHOUT PICS, IT NEVER HAPPENED!!!
Here's what I started with..
Here she is after I got her running. Getting ready to start the frame mods.
First thing I did was cut the tail section off just behind the shock mounts..
You can also see where I mocked up an 11" 'shock' to see how low I want to go with the rear end.
This shot shows the area of the frame I'm going to change. I want it to follow the lines of the side cover closer...
Next I carefully measured and marked where I wanted to make the cuts to bend the seat section down.
I made a second cut to give me some room to contour the new end sections so they would mate up with with down tubes later.
Then I heated the frame and bent the seat section down till it met the 'down tubes'. I also moved the end of the down tubes in about 3/8 of an inch.
Here's the job when I got done welding and grinding...
And here's with the side cover on.
My only concern is if there's enough strength in the frame at the shock mounts now. I was thinking of strengthening it with some gussets or maybe like this...
FEB 2009-
UPDATE:
Okay...so being laid off and sittin' around the house goin' stir crazy...I decided to suck it up and brave the cold....
Alrighty then...so I picked up a rear fender , and seat and did some cuttin' and slashin' on those. Because the fender was wider than my rails I was going to try to have it mount coming up from the tire, instead of dropping in like normal.....baaaad idea. It left me with some very large gaps that my seat wouldn't cover (no pics of that abortion... sorry
The fender is a Rick Doss "Dixie" Here's the stock version
Well, first thing I decided was the frame needed to be wider. So I split the cross brace, heated up the frame and spread it out about 1 1/4" and welded in a spacer. I made the spacer a little smaller then the cross brace so I can weld a small 'tongue' on the fender so that will help locate it without interfering with the seat.
You'll also notice I went with the topside gussets to strengthen the frame for the shocks. So with the wider frame I was able to drop the fender in from the top....But that meant I had to make some modification the to fender and eliminate my boo boo. So basically I cut off the snafu'd part, rotated the fender to bring the tail up and also removed the flat section. I don't have a pic of just the fender ..but you'll see it later
So next I started on the seat....
I picked this LePera up from Ebay..
First thing I had to do was tear it apart so I could modify the pan. Then I cut 2 clearance slots in the pan for my frame rails...(I also moved the tongue on the front of the seat so it would work like a stock Maxim seat
under the tail of the gas tank but I did that after everything else.)
I then took a piece of exhaust pipe steel and cut and ground and hammered and bent the puppy until I had made a liittle 'hood' to go over the rail and give me something to rivet the seat cover to.
It's kinda hard to see...but this is what the bottom of the pan looked like originally.
Then I used a wire wheel to clear out now-excess foam on the seat...
So it would fit correctly on the modified pan..
You'll notice also that I took the mounting tab and moved that inboard more so I can add a mating tab on the frame rail, then I can bolt them together to secure the seat
Then I riveted the seat cover back on, took it out to the garage and did a quick test fit with the fender
I LIKE where this is going
One nice thing about my fender snafu...it left me with a piece left over that worked quite nicely as an integrated tailight housing.
That's all for now. Next on the agenda is to fabricate some fender struts, get the shocks on and finalize the back end details.
Update - Tail light:
Been working on the tailight / turn signals and I can't make up my mind. One way would be easy and quick but I am thinking about an even more custom look. I'll give you guys the option and you can help me decide.....
I picked up some LED turn signals and a flexible strip of LEDs for the brake light.
Then I fabricated a mounting bracket for the tail light to mount on.
Drilled and tapped it for 10-32 screws to hold it on the fender.
Then I'll mount the LED strip to it for my brake light, which should look something like this..
I took a piece of prismatic plastic from a florescent light and trimmed it to fit the cowling.
Plan is to laminate transparent red over this eventually.
So here's where my other idea came in... If I go with my original plan with the turn signals mounted on the fender the end look would be kinda like this (the signal is small and on the left side of the fender)
But... then I thought " What if I take the LED turn signals apart and mount them along side the tailight??"... (only one is shown to the right of the tail light)
And the split the lens with red in the middle and clear on the sides so it would look like this..
Got the tail light 95% done so I thought I'd post some pics of it. Turned out pretty good
I think with the addition of the strut signal I should be pretty safe...well as safe as anyone can be on two wheels around cages...
With no lights on..
With just the brake light.
with the left signal and brake...
and finally with the right signal and brake..
-MARCH 2009-
Got my handlebars and shocks in. I'll try to get pics of that tomorrow.Gonna try to get the handlebars replaced since this set has a pretty poor chrome job done on it...but I digress....
Now that my shocks are in I can start proto-typing my fender struts. Got my first set made tonight...
Now all I got to do is have them machined. I'll probably start by machining one out of wood to make sure they will fit. That pic is what I modeled up in some cad software. The GHC is the initials for the name of my "business" - Green Horse Customs....The slot is for the flush mount signals I'll put in the struts for better viibility.
Well here's the pics I promised of the bars and shocks. Had to remove the lower bracket for the shock and fab a new one. These are 11" harley shocks and they're nice and stiff so I won't have to worry about bottoming out on the fender.
Here's one with the cardboard strut stuck in place to test fitment and alignment...as best as I could with a cardboard part anyways..
You might notice the strut looks different from my model. I had to revise the original strut because I made that one before I was finished with the seat. Glad it was just a matter of cutting cardboard and not re machining steel!! 8O phew!!!
The handle bars are 1" with a 4" rise. I slotted the existing holes in the top of the tree. Still got a ton of work ahead of me.....
-APRIL UPDATE-
ok time for an update.
Got my new 1" handlebars with the new controls all put together....
And while I'm waiting for my soda blaster to get here I started buffng out some of the engine covers. Here's what I started with...
Left side of the engine...
And the finished covers...
Right side...
and what I have done so far...
I also started on the top of the triple tree. I tried blasting it with one of those Harbor Freight $100 soda blasters....it took me 30 min to get about 3/4 of the top side done ..so I took that back and now I am waiting for my Eastwood blaster. For grins I did some sanding and buffing on what I had blasted to see if I would need to paint it or not when I'm done....here's the results so far...
-MAY UPDATE-
Just got my frame back from powder coating!! Looks fantastic!!! Found a local place that sandblasted and coated the frame, swingarm,side kickstand,center stand,and swingarm brace for $175 8O
I was going to go with a basic black but they said they could do it in what they called "silver veining" for the same price. I had them do the center stand in black because I don't think I'll be putting it back on the bike, so I figured when I sell it the new owner will love that it looks brand new!!
The place is called Custom Powder Coating and they're in Grand Rapids. Most other places I found wanted over $200 (some as high as $245) , and that was for basic black! If you wanted other colors, that was extra. Custom told me that it didn't matter what color you wanted, if they had it in house, it was all the same price!!
Great guys to work with!! I know who my pc source around Grand Rapids is from now on!!!
Here's some pics..
- JUNE -
WOOHOO!!! Got the prototype strut finished!!! I used a piece of 2x6 pine and since I can only turn about 3500 rpm's (no high speed head) the cutters left a lot of 'fuzzies' . But at least I can test fit and make the needed changes
The wood was also about 1 1/2 inches too short , but the tail section is the area I was most concerned with.
The model..
The prototype....
I didn't cut the styling groove or the logo in...I'll save that for the real thing. Wow...between learning how to build a rotary phase converter, wiring the machine, learning the CAM software, learning G-code for the machine, figuring out how to get the machine communicating with a laptop...my brain needs a vacation!!!
Now just have to make a few minor adjustments, then on to cutting aluminum!!!
-AUGUST-
Time for an update
Finally got done painting the engine. Pulled the head, cleaned her up real good and used some high temp ceramic paints..
Got most of the covers on. As soon as my metric feeler gauges come I'm gonna check valve clearances, make any adjustments then pop the motor back in. I'll try to get another 'mostly-assembled' pic of the motor tomorrow.....
With the aid of fellow member lowlifexj , I
think I got the new controls wired to the xj harness. Once I verify everything works I'll throw up a wiring schematic for those interested.
Finally decided on a front fender!! WOOHOO 8) That came in on Monday. Since the mounting bolts had a 6" spread, I needed to fabricate some front fender brackets. So I modeled some up...
Took a .250 think 4x7 plate of aluminum, threw it up on the ol' cnc and milled then out , bolted them on to the fender and slid her in....
Still working on machining out the rear struts...got one about 65% done...it's frustrating when you have the time to do the work....but not the funds :? I'm running out of things to sell too!! 8O lol Not stressing about it though, I just decided I'd push back the finish date to some time next year ... how long can you work on a project before it officially becomes a hobby?!?! LOL
Finally got both the struts machined !! Woohoo
Had to rework the backside so they have a nice tight custom fit. Here's the right side all fitted...
Took the right side strut and finish sanded/buffed/and polished. The left side is is fresh off the machine
-SEPTEMBER 2009-
Well, I got the motor in yesterday and finished wiring everything up. I put the exhaust on and slipped on the HD mufflers I got last fall just to see how it will look. I'm not totally sold on the mufflers yet. I'm thinking of trying something simple like the chrome turndowns Strat did on his 85....what do you guys think??
That's all for now....I'll try not to wait so long between updates...lol
