Hey all,
I had a thread a couple/few months ago about my vt500c not wanting to start and decided after a compression test to tear the engine down, well here is my update to that and my issue as it stands now.
My compression ratings were low in both front and rear cylinders, after tear down I found the rear cylinder had a nasty scar across the middle of the cylinder and the front had a broken piston (between rings), but had not scarred the cylinder. I had ordered a replacement cylinder and piston off ebay, piston was good, cylinder was cracked. Got a refund for the cylinder about the time I scored an 84 ascot locally for $250 that I could use for parts, it had a lot of usable parts for my shadow. Pulled the rear cylinder and behold it's usable. Honed it and the existing front cylinder and put it all back together with new rings and gaskets, put the engine back in the frame and tried to fire it up. No luck. I am hooking to my car battery and it turns over fine and occasionally will give a really explosive backfire out the rear exhaust pipe (I just have headers installed for now). I have everything installed on the bike except the full exhaust and the tank. I am using a bottle with the lid drilled out and a fuel line inserted so that I know for a fact that it is getting good/clean fuel.
Thinking that I may have screwed up the timing of the cams, I took the valve covers off (with the engine in the bike), and followed the sequence in the service manual and clymer manual to check the cam, cam chain, and cam sprocket alignments and it all seems right (unless I am misunderstanding it), since it really seems like a timing issue (the compression is good, it was the first thing I checked). My take on the cam timing is that you do front first, then rear:
- Turn the engine to F.T. mark, install front cam (lobes down), install sprocket in chain and put on cam (make sure timing marks are parallel to head surface), temp install bolt in exposed cam bolt hole
- Turn crank 180 degrees to F.T. mark again, install cam bolt in exposed hole
- Turn crank 180 degrees again to F.T. mark and tighten temporary cam bolt.
- Turn crank 232 degrees to the R.T. mark, install rear camshaft with lobes facing down, , install sprocket in chain and put on cam (make sure timing marks are parallel to head surface), temp install bolt in exposed cam bolt hole
- Turn crank 180 degrees to R.T. mark again, install cam bolt in exposed hole
- Turn crank 180 degrees again to R.T. mark and tighten temporary cam bolt.
Any ideas/insights, is my take on the cam timing right or am I doing something wrong, the clymer manual has a little different cam timing procedure that doesn't make a lot of sense to me. I am really considering just turning the rear cam 180 degrees and see how that works. Getting incredibly frustrated with it, but really want to get her running again, I repainted the whole engine black and the exhaust with black header paint and she is looking quite sexy, if I can only get it running, I can move to painting the body parts.
