Ok, well I discovered this on accident I guess. I wanted to bleed my clutch and went to remove, what I thought, was the cover on the left crank case to access the slave cylinder. I loosned 3 bolts from the wrong cover which is the one directly to the right of the round clutch basket. Once I had these loose and realized I had removed the wrong cover I was getting a drip from the bottom of the bike that looks like milky oil coming right off the rad hose connecting to the water pump. I immediately thought my head gasket was toast but my coolant level looks good and when I check the oil on the dipstick it looks normal. Bikes runs fine and doesn't seem to be smoking at all. I should mention that when i tighten these three bolts back up the leak stops. I'm pretty confused on this.
The bike is a 94 vt1100c with 30k miles.
