1 - 14 of 14 Posts
2002 Honda Shadow Spirit VT750DC
I got a used 2002 VT750DC and the person that had it before me made a mess. They installed custom LED turn signals in the front only. They worked, but the stock rear signals don't work. I cut out the custom lights and now I'm left with a mess of wires. The goal is to get it stock again. I have no idea what goes where. If someone could explain it to me like I'm 5 I'd really appreciate it a ton.
Automotive tire Motor vehicle Automotive lighting Steering wheel Rim
wiring diagrams should be in the back of these manuals
Reactions: "Captain D"
1998 750 ACE
Was gonna state Light Blue turn & Orange Turn
Rear have White stripes > I think I remember,
Dennis
EDIT
Looking at chart @Ramie posted here^
I see
blue & orange with white stripe feed those circuits???
1998 750 ACE
Check voltages on them blinker wires, along the chart, tie into them with your new/stock blinkers...
Discussion Starter · #8 ·
Thanks everyone for the help. It appears my turn signals are different. Each turn signal has 2 wires: black and black/white stripe. Remaining wires in the headlight assembly are the cut wires in the image.
Motor vehicle Automotive tire Automotive lighting Rim Spoke
Probably aftermarket, since black and black/white are not the normal colors, and those wires go into a shiny black plastic cover that looks newer than the original wiring.
Discussion Starter · #11 ·
Progress! I did a quick and dirty twisting job and the front lights are working, but NOT the rear. The wires with the white stripes are apparently for running lights, don't need those. Any suggestions as to why the rear lights aren't working?
Automotive lighting Hood Bicycle tire Bicycle handlebar Automotive tire
1998 750 ACE
Do I remember a white or black trace on them orange & Light Blue rear wires??
I think I do?
I ain`t been into mine in so long, i am not sure...
Remember the rears do NOT have running lights
Chart don`t mention rear turns, I prolly dreamt it about them rear wires and they`re Light Blue & Orange respectively,
Dennis
Discussion Starter · #13 ·
UPDATE: Mystery solved! The rear ones weren't working because it's an old bike and the connections under the fender went bad. Rewired and working! I got a 4 pack of incandescent turn signals, and they have the fast blinking issue. Not a big deal, just glad they're working!
1998 750 ACE
For the Rapid Flash or Hyper Flash some call it, Check the (green) ground wires and the flasher unit,
Dennis
1 - 14 of 14 Posts
