How do you get to the bottom radiator hose to tighten it ?
Hey Gabriel,
Is there any chance you could take a pic of the hose in question and put it in a post?
I read your question/reply in the other thread, and am slightly confused about which bottom radiator hose you are talking about. In the other post you typed, you said the hose started leaking after you removed the seat and side cover.
The lower radiator hose runs from the bottom of the radiator to the water pump inlet that is behind the left side lower frame rail. A flat blade screwdriver or 7mm socket is all that is needed to tighten the clamp that holds that hose to the radiator and the water pump inlet. I mention this because the lower radiator hose is not anywhere close to the seat or side cover.
Is there any chance you are talking about the short piece of coolant hose that attaches from the water pump discharge pipe to the lower backside of the rear cylinder? If yes, then the easiest way to tighten the clamp at the bottom of that hose is to first remove the lower left side crankcase chrome cover. The chrome cover has 2 spring clips behind the top section (maybe 6 " apart) and one 10mm nut in the center bottom that have to be removed before the cover will come off. With the clips removed and the 10mm nut removed you have to tug on the cover side to side to disengage the retention pins from the rubber grommets that they seat in. Once removed, it makes it easier to tighten the hose clamp.
John
