1 - 2 of 2 Posts
I bought a 02 Honda Shadow ACE 750 from a buddy and we replaced the clutch/brake cables. We did the clutch adjustment and have it sitting where it needs to be. When the bike isn’t running you can run through the gears, but once you start it it only shifts into first and I have to hit the kill switch in order to get it back into neutral. Would it be to much slack on the clutch cable itself or a slight bend in the shift rod? All advice is appropriated
Do you have about 3/4 inch free play at the end of the clutch lever?
Does it drag the bike when in 1st and the lever is all the way pulled?
What type of oil is in it?
1 - 2 of 2 Posts
