1 - 10 of 10 Posts
Hey everyone
I have a 2007 Honda shadow VT600. I bought this bike last year used and in excellent condition with 9,300 miles on it. It was always serviced at the local Honda shop and I am the second owner.
I have yet to take this bike on any long rides. I have mostly just taken it out around town for no more than an hour or so. I was riding the other week and had only been on the road for about 15 or 20 minutes. The bike suddenly started to choke out on me, power would come and go and a then it finally died. I pulled to the side of the road. I was riding with a buddy of mine and he said that he saw my lights in his rear view just go out. I turned the key off, checked my gas and everything seemed fine. Turned the key back on and hit the start button and nothing happened. We started to take the side panels off to see if the battery cables were tight and we smelled electrical burning smell. The battery cables were tight, we checked all of the fuses which checked out fine. I had to trailer the bike back home. I put the battery on my charger and it showed that it was charged. Put it back in and everything comes on but when you try to start it that starter just grinds and the engine won't turn over. I've talked to a few people and some of them have said it may be the stator. Any ideas? Any help would be greatly appreciated. Thank you.
Discussion Starter · #3 ·
I haven't found any wiring that is worn or has a poor connection. My battery shows that it is charged but it won't turn the bike over. I stuck it back in and jumped it and it would run and idle on its own but the lights flicker. I'm assuming that is because the battery is shot and what I'm seeing is the stator being the only thing keeping it going and the flicker is from the plugs firing which momentarily drains the power. In going to put a new battery in and see how it goes. I appreciate the opinion.
If you jump the battery and leave the jumper on it will it run good?
If so, then test the charging system while it is running to see if it can work at all. Then with the meter still connected pull off the jumper and watch the voltage to see what is happening.
Discussion Starter · #6 ·
I'll jump it again before I buy a battery and see. I haven't had a bolt meter on the battery yet. I've been working 14 hour shifts every day recently and haven't had the time to mess with it. I've got over a week off now so I can actually make some progress. I jumped it off the first time and it started right up, I pulled the jumper cables off and it idled fine but the lights flickered. I believe the battery is gone and all that was keeping it running was the stator but I'll jump it again and out the bolt meter on it.
Your quote. Check real close, Pull the wiring connectors out on the right side behind the side cover and look real close.
Check the three yellow wire connections (stator wires) under your seat. If the plug is burnt up chances are your system is fried but if not solder those 3 wires together and have the battery load tested. The 3 yellow wire connections is a major flaw on most metric bikes and seems to have gone unnoticed/forgotten on the forum of late. In ole' days of the forum it was preached to do this revision before any electrical failures arise.
What Do I Check When My Motorcycle Won't Start?
A motorcycle engine needs three things to start: Battery, Fuel, and Ignition. Any one of these three will prevent your bike from starting. We will address each of these, but remember that some of this information may not apply to your specific motorcycle.
While we cannot address every possible reason why it will not start, we can cover the basic things you can check yourself, with just basic hand tools.
In all cases, if you are not comfortable with getting your hands dirty and tearing things apart, then arrange for a reputable mechanic to work on it and save yourself the aggravation.
Many of us have had a brain cramp and overlooked that one really simple thing; and while these might seem obvious, before we get into troubleshooting, there are a few simple things you should check before you start taking your motorcycle apart.
• The fuel petcock is on, and there is fuel in the tank
• The ignition key is in the On or Run position
• The Kill Switch is in the Run position
• The Kickstand is up
• The transmission is in Neutral
If the bike won’t start, you will have to investigate further.
THE BATTERY
The battery must be fully charged, especially if it is a new one. Most battery manufacturers recommend you slow charge the battery overnight. If you don’t already have one, a trickle charger or Battery Tender is a good investment; as is an inexpensive voltmeter.
With the engine off, the battery should read in the vicinity of 12.5 volts. When the engine is running, it must be rotating at roughly 1,500 rpm or faster before it will begin to charge the battery. With the voltmeter still attached, rev the engine and you should see a reading of approximately 13.5 volts. If it does, then the charging system is operating correctly. When idling, the motorcycle is running off the battery, and if you let it idle too long, it could exhaust the charge in the battery, and the engine may die.
If you press the starter button and the engine turns over, but does not start, then the problem is most likely NOT the battery. If you press the starter button, and nothing happens, then the battery may be dead, OR you may have neglected to do one of the basic things, like turn the key on, or put the kickstand up.
FUEL
Make sure you have fresh gas in the tank, not some stuff left over from last year’s riding season. If you are not going to drain the tank for the winter, then make sure you use one of the commercially available stabilization products like Sta-Bil or Sea Foam.
If you have just tried to start the engine for the first time in a while, then the possibility exists that your carburetors may be gummed up from sitting. The appropriate amount of Gumout or Sea Foam may help; but if it doesn’t, you will probably need to remove the carburetors, disassemble them and clean the gunk out of them.
Make sure the fuel petcock is turned to the proper position. You most likely have an On and a Reserve position on the petcock. If the tank is low on fuel, you may need to put the petcock in the Reserve position. If you have cranked the starter, and the engine does not start; check to see that you have not flooded the engine. I good indicator of a flooded engine is if you can smell a strong odor of gas near the carburetors. You can also remove one of the spark plugs and check the electrodes to see if they are wet. If you smell gas, or the spark plug electrodes are wet, you may have flooded the engine. If so, then make sure the choke is Off, let the bike sit for a bit, and try to start it again, this time without giving it any throttle.
If you do not smell gas, and the spark plugs look dry, then you may not be getting any fuel. Your gas tank may be equipped with a fuel line filter, either near the petcock assembly, or somewhere in the fuel line itself. Check them to make sure they are not dirty or clogged; if so, replace them. Your gas tank may also have a vent line which may be plugged or pinched. If it is, the engine will not be able to receive fuel.
Remove the gas filler cap, and if you hear a hissing sound, like air being sucked into the tank, then the vent may be the problem. Try starting the engine again. If it starts, then shut it off right away and resolve the vent problem. There have been reports that clogged vent tubes have caused the gas tank to buckle or collapse due to the vacuum created in side the fuel tank by the blocked vents.
If everything looks OK, and you have a can of starter fluid or a spray can of carburetor cleaner, you can try spraying a small amount into your air intake, the try to start the engine. If it fires up, but then dies right way, then you are probably getting spark to the plugs, but not getting fuel to the carburetors’ and you may have to tear them down and clean them. Do NOT keep spraying stuff into the air intake; you may damage the engine that way!
If you still can’t get the engine to fire, then you may have ignition problems.
IGNITION
There are 2 basic ways to check to see if you spark plugs are firing. You can leave the spark plug installed, and pull the rubber boot from the plug. Stick a screwdriver into the rubber boot, making sure the end it touching the connector inside. Hold the shaft of the screwdriver about 1/8 of an inch away from the engine block and crank the engine. If the ignition is sending juice, you should see sparks jumping the gap between the screwdriver and the engine. This will tell you if the coil is delivering spark to the plugs, but it won’t tell you if the plugs themselves are bad or not.
An alternative method is to pull a plug, check to make sure that the gap is within the manufacturers recommended specification, and then connect the boot to the plug again. Hold the electrode against the engine, then crank the started and see if you can see spark jumping the gap of the plug. You probably want to hold the plug wire with rubber handled pliers, unless you enjoy getting zapped.
If you don’t see a spark, then you may have ignition coil problems, or other issues. Find the location of the coil on your bike, it may be under the fuel tank, and make sure all wires are connected correctly.
Using fresh gas, new plugs, choke in the off position, try starting the engine. If it still won’t start, then you will need to check for things that are outside of the scope of this post. If your motorcycle starts and stays running, then it’s time to celebrate and go riding. Don’t get too far away from home though, just in case you missed something.
1 - 10 of 10 Posts
