1 - 20 of 25 Posts
Hi. Love this forum. I have been lurking for bout 3 weeks.
I am new to the world of motorcycles in general. I've had a Suzuki Burgman (400cc scooter) for the past 2 months and I just completed the MSF Course about 1 month ago.
After looking all over the place for a classic Shadow...one in good condition, but not so nice as to where the owner thinks it's a classic car with a "classic" pricetag... anyway, I found it and brought it home this weekend...a 1986 VT500C with almost 10k on it. In pretty good condition...will post pics as soon as I get it detailed.
The bike runs pretty well. I went through it today making the cable adjustments, brake adjustments, etc... I fixed 3 electrical issues too. There is only 1 remaining problem. The throttle itself does not stick...when I rev it while stopped, it comes back to idle (not too fast but I think about normal). However, when I am riding, and I let off the throttle to pull in the clutch lever to shift gears, the RPM's do not come down quick at all. In fact sometimes they don't come down at all or increase. So needless to say my shifts are rather jerky. Yes, I am letting off the throttle completely.
The only way I can shift smoothly is to pull in the clutch, then hold it until about 2 seconds after shifting up (at which time the RPMS finally start to drop), then easing out through the friction zone. Can you say SLOW shifts!.
Anyway, how should I even start to trouble shoot this? If it were a basic throttle cable adjustment needed, wouldn't I have an issue with the throttle while sitting still? And if it is not that, could it be a carb related issue (out of sync?). I have not done a tune up on the bike yet. But the air filter isnt very dirty. I have not pulled the plugs yet (next week). The bike is cold blooded but idles fine at 1000rpm after its warm when sitting still. However, while riding and come to a stop sign, it idles at 1500... One other possible problem or symptom is that when I start the bike cold with half or more choke, the RPMS's will shoot up to 5000 and I have to move the choke lever quickly back down to about 1/4 to get it down.
Any thoughts? Also, is there an inline fuel filter on this bike? I know about the fuel screen in the fuel shut-off valve...
Sorry for all the questions.
welcome to the forum bro i just recently purchased my 85 500cc and i stil lhavent got her running but nice to see new blood so i dont feel so new haha, if i could help i would but a warm welcome bro
edit: oh i forgot they will tell you to try to search, there is alot of good info on here through search, but most people even if you dont search will help you which is a really good facet about this forum good luck
Make sure the throttle cable isn't hanging first. If the cable is OK then the slide in the carb, or carbs, is possibly sticking. Yes, there should be a fuel filter. Someone else should chime in to be of more help. Good luck
Sounds like you have 1 of 3 possible problems.
Providing neither of the throttle cables are sticking and BOTH throttle cables are hooked up:
A. You have a pinched breather line on the carb(s). **Most likely cause**
B. You have a burr or dry slide inside the carb and it's sticking.
C. You have a weak spring in the carb that keeps the slides pushed down when not under throttle.
Discussion Starter · #6 ·
Thanks for the welcomes and the advice.
I love the bike. I have already done over half of the entire recommended maintenance procedures in the Clymer manual.
I took out the air filter yesterday and thought it was clean. Then today, it hit me...these filters are not like car air filters. Motorcycle air filters get dirty from the inside/out. So I looked inside the filter and found 2 things. First, an 11/16" socket. Somebody must have dropped that when working on the bike and it went in the intake and into the filter. Second, the inside of the filter is filthy. I have one on order.
The throttle cables are not hanging up and the throttle itself is lubed as are the cables (Did that just today). They were not sticking beofre I did it though.
Could the filthy air cleaner have caused my issue? I noticed while sitting on the bike with the seat removed, if i put my hands over the intake tubes, the RPM's shot up. So I am guessing the bike was starving for air... when I was in gear about 3500 RPM's and went to shift, the bike was not getting enough air and the dirty filter was acting as a choke... I have no way to tell if it is fixed until I get my air cleaner.
I also bought some Seafoam and put that in the gas tank today. If the Air Filter does not do the trick, is it possible that the seafoam will help unstick the slides? I will also check for a pinched breather hose. If none of thagt works, do I have to remove the carbs to R&R the sliders? I am decent mechanically, but know nothing about carburetors...
THANKS
Easy way to find out....remove the air filter, vacuum out the filter box and take it for a short ride........
I did this when I was trying troubleshoot a lean/rich condition. Significant difference in the way it acts at WOT without the filter, even a clean filter.
Huh? You lost me on that one.
Rick
Discussion Starter · #10 ·
Rick
I used to race stock cars. The air cleaners on the old carbureted engines surrounded the carb and got dirty from the outside/in. With a motorcycle, especially the 86 Shadow, the air inlet goes directy to the inside of the filter, the air travels from the inside/out to the engine...
Discussion Starter · #11 ·
Rick
Remove the throttle cables and see if the throttle plates are hanging up, a dirty air cleaner won't cause your problem, neither will a sticking carb slide, it'll just make it run very rich, the throttle plates control rpm....check for vacuum leaks, you said that you held your hands over the intakes and the rpm's shot up, vacuum leak.....typically, sticking throttles are caused by bad cables more often than not.....if you have a bad vacuum leak and someone tried to compensate by cranking up the idle speed....it'll do that...also, if the idle circuits in the carbs are plugged and the idle was cranked up to compensate....it'll do that.....start with something simple, like old, nasty cables and go from there....good luck, Mick
Actually, a sticking slide will cause RPM to increase.
When you choke the bike, the RPM increase and the throttle blades don't move.
A sticking slide will do the same thing as a open en-richening valve.
The throttle plates do not control the RPM solely, either.
Throttle plates control the air flow or more correctly, venturi pressure.
The slides control fuel flow and they both work together to regulate RPM.
Well, I'll be darned. I wasn't challenging you, just didn't know that. My last bike was 18 years ago, and on this bike I haven't had it long enough yet to have a reason yet to take a look other than curiosity.
Rick
Discussion Starter · #16 ·
I actually did check this when I took the throttle cables apart to lubricate them. Other than being slightly out of adjustment,they were not sticking. Besides, when the bike is sitting and you rev the engine, the throttle does not stick. Once the bike is warm and the choke is off, the rpm's comes back down to 1000 and hold every time, even if I let off the throttle really gently. The problem with the "sticky" throttle only happens when actually riding the bike and letting off the throttle to shift gears. Especially if you shift at 3500 or more RPM. Sometimes when you roll off and squeeze in the clutch lever, the RPM's hang for a second or two, or they shoot up to 4500, then come down....
Discussion Starter · #17 ·
This certainly sounds to me (like I know anything) like it is plausible. Since the bike has only 10k miles and I don't know the maintenance history, the carbs probably are gummed up to some extent. I figured I would change out the air cleaner, adjust the valves, replace the plugs, clean the fuel screen and replace the fuel filter, and run some seafoam in the gas (already put that in yesterday). Then if the problem still exists, it HAS to be the carbs (I'm guessing) or a vacuum leak. As far as the carb slides...how do you check them to see if they are sticking? Can I do this with the tank off and the carbs still on the bike or do I have to remove them? If they have to be removed, I will probably clean them and replace all the seals while I am at it...but would rather not if I can solve my problem without removing them. Any chance the seafoam will help unstick them?
If I have to remove them, should I sync them too? I do not have a mamometer (sp?)...can I take them off and take them to a shop for that?
Are there any common areas to look for vacuum leaks?
THANKS everyone for all the help and opinions!!
Rick
My 85 VT1100 is the same way, air flows from the inside out. I have changed many air filters on bikes, cars, farm machinery, and industrial machinery including turbines. I believe the Shadow is the only filter I have seen that flows from the inside out.
In 1988, I had the Shadow at the Rider Rally in Cody. Yellowstone was on fire. The smoke blocked out the sun in Cody 50 miles away from the nearest fire and ash was falling from the sky. Visibility was down to less than 100 yards in some places in Yellowstone. When I got home, the air filter was solid black part way on the inside of the air filter. Part way because there is a lip that goes up part way inside the filter. It looks like a lot of flow restriction, but the bike runs good, so I leave it alone and don’t second guess the Honda engineers that built it for me.
SeaFoam generally won't help a sticking slide, unless it's sticking at the needle, where it goes in to the needle jet.
If the slide itself is sticking, you have to remove the diaphram cover
to get them out.
If it's the needle sticking, SeaFoam could possibly help.
You're doing all the right things in doing possibly overlooked maintenance.
A vacuum leak can occur anywhere there is a rubber vacuum line connected.
Don't just look at where they are connected though, pinholes in vacuum lines also are source.
They can also occur at the isolation boots that hold the carbs to the head.
If they have a lot of age on them, it wouldn't hurt to replace those also.
They will get dry and can leak there.
There are two ways to check to see if the slides are sticking.
Both ways require having the carbs off.
With them off, you can open the throttle blades and very gently lift
the slide with your finger. It should move up in the bore freely and return
freely.
The other way is to very softly blow and suck in the vent tube.
This will cause the slide to move and fall. Again, it should do so freely.
It is definately a good idea to resync the carbs after you've removed them.
It's not something you can take off and take to the dealer to get done.
It has to be done on the engine that the carbs are on.
The reason is that manifold vacuum is not exactly the same across all
engines. You cannot sync your carbs with your two cylinders
and then take those carbs and move them to a different bike.
The health and efficiency of each cylinder detmine how the carbs sync.
When you synch the carbs, you are sync'ing them so they will pass
the same amount of air between two cylinders.
Talk to MarkC or cbjr0256. I believe both of them have successfully made
manometers out of clear tubing.
Either one of them can direct you or tell you how to make one that
you can set your carbs with.
I have a set of Honda 4 gauge units that I use, but if I didn't, I sure
wouldn't hesitate to make one like they did.
Discussion Starter · #20 ·
litnin - Yeah I am doing basically every maintenance procedure and tune-up item listed in the Clymer manual...I gotten about 3/4 of the way through the non-tune up items.
Thanks for your description of how to check the slides. I will still have to do some reading because I don't even know what the slides look like.
I probably will go ahead and replace all vacuum hoses. I am also going to replace all the fuel lines. But before I do that, I am going to do the tune-up items including the air filter and ride the bike again to see if I still have the problem. Just for curiosity sake I want to know what exactly was causing the problem, and if I change out too many things without testing in between, I'll never know.
THANKS for all the help everybody...I really appreciate it...
1 - 20 of 25 Posts
