Hi. My name is Quinten. I recently got a bike handed down to me from my father and it has sat for about 5 years. It is a 99 Honda Shadow VT750 with only 5k miles on it. I have previously worked and restored other bikes but this is my first shadow that I have worked on. I started by replacing the battery and then the bike started up with some starter fluid in the air box and it would run for a few second and then sputter out. So I took out the carb and did a deep clean and rebuild on it (which I am always very thorough with and use an ultrasonic cleaner and everything). I put the carb back in the bike and sprayed some more starter fluid in it to get it moving and same result. Only started for a few seconds and then sputtered out. I replaced the spark plugs and I know it is getting good spark as well as good compression. So I opened up the drains at the bottom of the carb to pull it out again and do a second cleaning and nothing came out. I have dissected the fuel tubing and the petcock works well (albeit a gravity fed petcock) and there is an inline fuel filer that fuel is getting through well. But, when I got down to the fuel pump (or fuel solenoid, im not sure which it is) the gas goes in, but when I turn the petcock to on, fuel barely dribbles out of it. Is this normal? Im not used to have a fuel pump, normally the bikes I have worked on only have a gravity fed line straight to the carbs. Is there a way to test if the pump is working? Do I need to replace it? Should I just bypass the pump?
Sorry for the longer post, just trying to get in all the details and what has been done so y'all know what I have already done. Any suggestions help. Thank you so much!
