i can't even think of words the truly convey how angry it makes me every time i see how horrible the dyno numbers are for on the vt750, a 750 with only 35 bhp is insulting.
I've only had the bike since june and because the bike hadn't been ridden in almost 4 years i couldn't test ride it but i figured a bike with only 6k original miles was a pretty safe risk, what i didn't know was that compared to the 80's vt750 i was familiar with, honda had added so many unimprovements to the newer vt750 like losing 30 hp, adding 100 lbs and on my particular model, eliminating the low fuel light but leaving the gas tank filler hole directly in the center of the tank so you can never tell how much gas you have left, you just see the center hump and then there's the crankshaft, changing the vt750's crank from a sporty 270 degree to a tractor like 360 degree, gives the shadow that special briggs & Straton minibike sound. The 18/38 gear combo probably wouldn't work on an off the showroom floor shadow but between opening up the intake and exhaust, major rejetting, and lowering the spring rate on the carburetor slides the bike is pulling harder then it ever did before although it's still not up to a typical 750 but at least now it's running good enough that i don't have an overwhelming urge to run over the bike with my truck every time i get off of it so that something......lol
I've read about people using the wet line on a stick to measure their fuel level, but that was from stories of cars from 100 years ago. There's not much to see when peering down into the tank on most modern machines, anti siphon features have done away with sticks into filler openings. For the last 40 years, I've been using my trip meter, to tell me when to expect the power to sag, signifying it's time to switch to reserve and look for a gas station. Before my machines had a trip meter, I made mental or paper notes of the odometer reading and added my range to that. Even on the couple of machines I own that have gas gauges, this practice proves to be more reliable than the indicator gadget.
There's benefits to a "low stress" engine design. As a guy who not only rides, but prefers, my Royal Enfield 500 single, with ~25hp at around 430 lbs, I should know. Lowish compression lets one use all sorts of swill for fuel, a feature I don't require, but which is almost essential for much of RE's main market in India. Large displacement for horsepower means the engine doesn't need to make rpms to generate torque, which, if well engineered, can mean a very long life and high fuel efficiency.
Consider the old design Lister diesel. (This picture is of a knockoff)
A 6 hp, 650 rpm, engine that weighs 750 lbs is a couple orders of magnitude worse than your Shadow 750 engine in specific power, but with no glow plug, no ignition system, and simple heavy duty construction, they can be rebuilt with a crescent wrench and have been known to run 25 YEARS continuously, as in NO stopping.
I agree with your point, Honda did deliberately remove power from the later Shadows. These new "pooch screwed" designs, then went on to sell in significantly higher numbers than their older brother from the 80s ever had. I have read that in 2000, the most popular selling machine worldwide was the VT600C, a machine that was rated at only ~39hp, but since it had chain, rather than shaft drive, it actually delivered more power to the rear wheel than a lot of 750 Shadows.
I agree, on paper and in practice, with the exception of those that have been tuned and modified like yours, the 750 seems to be the slowpoke of the Shadow family. Ironically, of this family, the 750 has sold in the highest numbers, and is the only Shadow still being sold.
Cruiser - Honda
One is led to conclude that there must be a LOT of people out there, for whom power and speed is not a primary concern. Those who ARE interested in high power and speed, or who don't value a "potato potato" sound over smoothness and horsepower, should probably do their homework before buying. You are here on the forum, so you must have access to the internet. Honda made no secret of the performance specs. Folks who wanted more could choose a different model, the Magna VF750C, for example, has around twice the hp of comtemporaneous 750 Shadows, and was sold up until 2003. They aren't expensive, one can easily get onto a used Magna for less than $4K.
If I was as unhappy with a machine I had purchased as you seem to be, I would not try to remake the sow's ear into a silk purse. I would buy my silk purse now, ( Here in the midwest, December through March is strong BUYER's market, nobody is riding, or buying, so good deals can be had from motivated sellers.)
Maybe I'd get this '96 Magna 750?
96 Honda Magna - motorcycles/scooters - by owner - vehicle...
Then, next spring, when folks thoughts were turning back to riding, I'd sell my 750 Shadow. I'd probably end up at least a few hundred $ on the plus side in the horse trade, compensation for my efforts in getting the Shadow back to running condition, and for taking advantage of the seasonality of the marketplace. When I was talking to prospective buyers, I'd try to avoid revealing my true feelings about Honda screwing any pooches, and let the machine sell itself.
