Make sure to order an OEM o-ring. I searched and searched for an aftermarket better type of rubber o-ring and couldn't find the exact size anywhere. While I was replacing the o-ring, it fit so tight that any other size would have never fit. I lubed mine up with plumbers silicone grease for a little extra protection and so it would slide into position better. Make sure to do a search for the shortcut on changing these out in place. That dental floss trick is great. Go to this under search and it will show you the best shortcut ever.
Found it under Technical Discussion: HOW TO: Water Joint O-Ring Replacement VLX600
