When I first start the bike and the starter turns over but doesn't start on the first try, I've began to notice at times when I bump the starter again nothing happens...total silence. Then I switch the key off/on and bump the starter again and it does turn the motor over, but again, if it doesn't crank on the second try, nothing happened when I pressed the start button again. Same thing, switch off, switch on...starter worked and bike started. And after running it on the road, after getting the current flowing, the starter works just fine.
This is an 86 VT1100, with a new gell cell battery...I did check the battery cables and they were clean and tight. Took awhile to locate the starter behind the rear jug, but when I checked, the cable connection seemed good and tight. Maybe check and make sure of clean cable to starter connection...but other than this...?
Starter? key switch? starter switch? and is there any relay or anything in between? Switching the key off and back on works for now, but not sure about later. Any ideas?
