1 - 16 of 16 Posts
looks like what some would call "dry rot". The skin of the tire dried out and cracked, yet the inside of the tire is still in tack. This posses a very dangerous situation. The tire could "blow out" at any given time. For that reason alone you should replace the tire.
Yup! Tire and Tube time! ;)
Hey .... It happens. I see bikes all the time with tire issues. Good thing is you actually looked at the tires before you were looking UP at the tires.
1998 750 ACE
I`m glad you found it NOW, insteadda after a crash!
Date code inside the oval stamp branded on the sidewall info (2709) similar to that...
27th week of 2009 is the birthdate on this code...
Curious minds want tom KNOW>>>
Us old timers would call the "May Pops".
Pretty serious on a bike compared to a car.
Went to ride today after 3 month storage and found a crack in my tire! It hasnt lost air. Why?????
Because the crack is in the rubber sidewall, not the casing. Plus you have a tube in there.
That didn't just happen while it was sitting.....when was the last time you checked your tires?
Get a new set of tires and have fun riding this year.
Discussion Starter · #13 ·
The date code is 0409. It's a tubeless tire and I check them all the time. I'm chalking it up to stupid Ohio winter of below 0° sitting on concrete. No matter what new tire is on its way.
My mistake, from the look of it I would have sworn it was an old perished tire..
but as I said with spokes that shouldn't normally be tubeless, and as it is six years old you should fit new rim tape and a new tube
John.
There is a tube in there though, unless you sealed the spoke holes up.
Looks like the bike has been sitting outside by the corrosion on the spokes and nuts. Would explain the dry rot on the tire also. I would replace both front and rear tires for safety and handling reasons. ;)
1 - 16 of 16 Posts
