Normal.
Like said its the crank case breather, its routed into the air box for EPA reasons. Bound to get a little more in the air box if you run the bike hard (hotter oil temps, needs room to expand) or have slightly over filled the crank case with oil. either way there should be a little tiny plastic bag clamped on to the air box as a collection point for this oil. Empty it out every oil change or so.
Ideally one would route the crank case vent into the atmosphere and keep the oil gunk from going into your intake and cylinders. I put a stage 1 intake with crank case breathers that vent into the atmosphere on my bike, and with only 4500mi on the bike and the stock intake I had a nasty black gunk coating the inside of my throttle body from the crank case breather set up in the stock air box. Also I've seen engine tear down pics from bikes with less than 10,000mi with and without the stock air boxes, and the ones with stock air boxes that have crank vents into the airbox always have much more build up on the pistons.
