1 - 3 of 3 Posts
I am curious if I can use one battery tender on two batteries at the same time. I'm thinking wired in parallel would be the way to go if its possible.
Yep.. Here you go:
Connecting Chargers - Batterytender.com
Highly suggested that you read the entire document and understand fully what you're actually doing (aka batteries should be the same voltage and amp hour capacity).
As stated, ideally the batteries would be of the same capacity and "age"... they must be the same voltage (12v most likely). We have two 12v batteries in parallel on our camper. We charge them with the standard onboard charger... same principle here.
Ride Safely!
John.
1 - 3 of 3 Posts
