Got a meter????
I`d check those fuses with a meter rather than replace a good one with a good one...
I`m not being hardnosed, I know you can`t read the fun intended expression, I put into these posts...
We are here to help, not to hender you through these difficult times of NONrunning motorcycle issues......
IF the battery is a good, 12Volt source, then you go from there...
checking connections until you find it...
The reason MOM says to disconnect the battery before working on it is to cover their burito...
I think it may be a safety item too, soas NOT to burn up anything, or have it crank up and run over you...
Help is on the way IF you`re between me and Sturgis...
