1 - 7 of 7 Posts
Hi Guys,
There seem to be a million products out there that claim to remove oxidation. The rims on my 83 shadow need a little TLC. Would love to hear some feedback before I buy one or more of the tons of products out there...thanks.. :?
oxidation or rust?
Oxidation can simply be removed by a good wax (carnuba) and
some elbow grease.
Rust, I may be thinking of something else, but I think standard Naval Jelly
is good for it.
Also, Coke and Aluminum foil is supposed to remove light rust (confirmed on Myth Busters too).
Waxing will not help you. You need rubbing compound
If you have access to a buffer it will be a lot easer. You can even use the mothers power ball.NAPA has a good selection of products to help you. You must remove the layer of paint that is oxidized once you get it removed the you need a good polish . They also have cleaner type wax that does a ok job But will not bring the true color back. After 20 in the automotive refinishing feild sometime you can buff it out and sometimes you cann't I you need step by step you can PM me and i will gladly go thru it or you can come to the chat room and ill talk you thru. hope this helps
What are your wheels made of?
Alumininim takes a different approach than chrome steel.
If chrome steel I'd use brillo soap pads to cut the rust/tarnish then finish with a chrome polish.
If alum, you need to strip with an alum wheel cleaner then polish with something like navel jelly or something made to polish alum.
8)
1 - 7 of 7 Posts
