The petcock on my gas tank has a leak from the bottom. Can I use a replacement that doesn't have the vacuum line? If not how hard to rebuild are they?
What bike do you have? @xxxxxxxclm1954, the vacuum line wouldn't actually pull fuel, it would just open and close the petcock.The petcock on my gas tank has a leak from the bottom. Can I use a replacement that doesn't have the vacuum line? If not how hard to rebuild are they?
The petcock still has an off selection but yes it more or less shuts itself off when you kill the bike and has enough vacuum from cranking to open it back upSo the petcock has a built in shut off valve. Is that what you are saying Harryc.
