I have a 2006 VT1100 with about 15,000 miles.
It starts right up and runs great. But sometimes after I've ridden to work, when I get on it to ride home, it starts up and runs for a few minutes and then I lose power/compression and it dies.
When I try to restart it, it will start and run, but if I try to give it any throttle it quits running. I don't know what's causing this and it's frustrating because I'm left stranded and don't know how to get it fixed.
I try to restart it several times, which takes 20 to 30 minutes. Finally she will fire up back into life with full throttle and I can ride her home.
I don't know if it's too much fuel, not enough fuel, not enough air, not enough spark. As best as I can describe it, it just all of a sudden loses power and dies. Doesn't want to run correctly until I've spent half an hour trying to restart her several times.
I had both carbs rebuilt at a Honda dealer a couple of years ago and I have a fresh air filter.
One potentially related factor is the choke. I open the choke to start it, and after the bike has warmed up, if I try to close the choke she doesn't run very well. Although I'm mechanically inclined, I never learned much about carburation, lean versus rich mixtures and so on. I've been riding with the choke open and I'm wondering if that has something to do with causing the problem?
What's really weird is that this problem doesn't happen usually on the first ride of the day. It's the second ride that she starts up and goes, but then dies after a few minutes.
Thanks for any help you can give me to understand what's causing this problem. I love to ride, but it's upsetting to have to worry about being late, or running the battery dead.
