I have a 2001 Honda Shadow Spirit VT750DC. It's acting like a Kawasaki...
I'm having a fuel issue that I can't seem to figure out let alone fix. The motor runs excellent at idle for about 5 minutes but the begins to sputter and pop then quit running. After waiting for a time period it will start and do the same thing. The engine seems to be starving for fuel. I checked the fuel pump and turned on the ignition but the pump did not pump fuel. I removed the bowls from the carbs to discover they both had a white powdery residue that some research suggested that i may have gotten some fuel contaminated with water. As a result I cleaned the tank with acetone followed with alcohol to remove any residual moisture. I cleaned the carbs with Gunk Cleaner and carb and choke cleaner also using compressed air. I have in the past done the same thing with good sucess. The spark plugs NKG Standard plugs were all carbon fouled. They were replaced with Iridium plugs and new NGK RACING Plug wires. I replaced the fuel with fresh fuel along with a K&N fuel filter. I rode the bike for a short trip (65 miles) one afternoon without incident. The next time I went to ride the same symptoms returned. I find it hard to believe the problems are in the carbs. All internal parts of the carbs were replaced. I tried the fuel pump and it did not pump fuel eventhough it had adequate fuel and 12VDC power to the pump. As a result I replaced the fuel pump. With no success. I tried every experiment I could conceive to correct the problem. I replaced the petcock valve. Tonight I disconnected the fuel pump from the circuit and directly wired the pump to an external battery and the pump worked flawlessly. I rechecked the power at the connector and their was 12 VDC. I plugged the pump back up and again the same symptoms reappeared. I disconnected the plug and using a test light determined there was 12VDC but when I plugged the pump back up then i had no power at the plug. I repeated the test that confirmed power but upon plugging the circuit together the same thing happened. Can ANYONE TELL ME WHATS WRONG????? I'M AT MY WHITS END. Any help would be greatly appreciated.
Best Regards,
Charlie
Best Regards,
Charlie
