1 - 2 of 2 Posts
I've got a 92 600VLX that starts fine but after about 15 to 20 seconds emits fuel from the drain line between the two cylinders. The line appears to come from the carbs. I'm thinking that I have a stuck float. Am I correct?
Stuck float, float level set too high, worn out inlet needle or debris under the inlet needle. Pick at least one. :mrgreen:
edit.
This is assuming, of course, that the fuel is coming from the carb vent line and not the carb bowl drain.
1 - 2 of 2 Posts
