1 - 3 of 3 Posts
I love the look of the yellow shadow. How much is it lowered? Did you lower front and rear both? Cause it still looks level. Last question, do you have any clearance problems when cornering? Using the rear struts, it looks like it could be returned to stock height if it had to be.
Thanks
The front is actually raised 3". I'm not sure how much the rear is lowered from stock as I never measured the shocks but the hardtail bars are 9.5" center to center. The frame / bike sits higher in the front but if I was to get a set of raked triple trees the bike but come back to a level stance. The bike corners and handles great but there is still a little "chicken strip" on the rear tire as I try not to grind up my pegs. All of the modifications are bolt on so the bike can go back to stock easily.
Discussion Starter #3
Thanks a lot for the reply. I may have to give some of those mods a try.
1 - 3 of 3 Posts
