Took the gearshift linkage off and the kickstand sensor wire was in front of it, which didn't look right (it was rubbing on the linkage shaft). When I put it back on just now, I put the wire behind. It's still rubbing.
Which way is it supposed to be? I know this was taken off once already by PO so not sure if the original way is correct.
Should they be rubbing? Am I missing something?
