1 - 11 of 11 Posts
1996 Honda Shadow VT1100-C2
I ran out of fuel today. It happened after I switched into 5th gear for the first time of the day, just a few miles from my house. For some stupid reason I thought the bike sputtering and losing power was due to upshifting too early and I was only going about 50 at the time .
Well, I drifted to a stop on a white section of the road couldn't restarted shut the thing off to let the starter cool down and then it occurred to me maybe I used up my entire tank-- at least the normal capacity of it-- in the last three weeks of very little riding?
I've been working on my bike's electrical system, taking it out for short trips here and there a few times a week but never more than several miles at a time. This is mostly driving on small roads with speed limit between 35 and 55 miles an hour and I spend more time in third gear than I do fifth. Hence the poor MPG.
After I let things cool off for five minutes,
I switched my fuel petcock to the "reserve" position and started cranking it. I added a little bit of choke ("fuel enrichment")after about five seconds, and that's what it took to fire up.
Then I filled the tank up at a gas station just a mile or two away and I actually overfilled it. Filled it to within a few millimeters of the bottom of the filler cap opening when I was sitting on the bike holding it straight up when I put the fuel cap back on and let it back on the side stand while I put on my gear fuel started leaking to the left. (I know my fuel tank cap has a compromised gasket; I did that deliberately last year when I was told I was having a vapor lock problem for lack of venting, but I don't think thst was true. I believe the tank's internal venting system works just fine but I've never bothered replacing the cap /gasket.)
So, just for those of you who are curious how much fuel it takes to completely fill a 2996 Honda Shadow vt1100C2 fuel tank after it has run out of its primary fuel and has started on reserve: 3.5 gallons.
I probably should only have put in 3.3 gallons to keep it from leaking when the bike is on the side stand.
Vehicle registration plate Motor vehicle Watch Bumper Automotive exterior
'99 VT750CD ACE
I practiced and memorized the motion of reaching for the petcock so that I can just reach down and flip to reserve
This was a quick subject addressed in the safety course I took. It's a good thing to know without having to look down, it's a motion that has come in handy for me!
On my 2015 Aero 750 (fuel injected), I have been wondering how the reserve fuel works. Does the reserve consumption begin when the light comes on (no need to open a valve)? Perhaps this spring I will pack an extra gallon of fuel and ride until I run out, just to see how it works.
1995 VT1100C2
I would like to designate June 1st as ISR Day: International reach down and Switch to Res and then back to fuel Day.
The once a year practice exercise will be good for operator and the fuel valve.
June 1 is also Heimlich Maneuver Day so it will be easy to remember. After practicing Heimlich, go for a ride. Warning: Do not do Heimlich while riding.
I rotate mine between off res and on every now and then.
1 - 11 of 11 Posts
