so a few of you might recall that i took my 1986 1100 honda shadow to a local known shop to help with my bike.so after some testing and using someone else's cdi box,i got my bike started again.my bike was purchased somewhat running,but sometimes it just wouldn't run,it had no spark,sometimes it would have spark and run great.i could turn it on and let it idle for 30 to 40 minutes,and it would run great,but if i took it on a ride for lets say,10 to 15 miles,i would loose power to rear cylinder,but still make it home.so finally it just would not start.SO guy at shop put in a cdi box that he had and bike started right.i rode the bike home,15 miles one way.i pulled over for some gas,put another 20 miles on it around town.so i decided bike is up and running,so i took it to work,just cruised on the freeway about 75 mph,after doing 20 miles,lost spark to rear cylinder again.i made it to work,it cooled off,got on it after work,it sounded great,rode it half ways home and it did it again.i quickly got home,let the bike run and idle on one cylinder,pulled the seats off and checked to make sure that there was power to coils and there was.the blinked rapidly with the test light on it,and the black with white stripe stayed on,those are for the rear,i checked the front wires,blue blinked rapidly and the black with white stripe stayed on.so i thought maybe coil is bad.i swapped the coils around,rode the bike just long enough to to cause the same issue and it did it again,but still only in the rear cylinder.
so my question is,could the plug wires be bad?i did put in four new plugs,but not wires.but could both the wires go bad when the warm up and return to running condition when it cools off
i could understand one wire,but both?
sorry for long post,but tried to post everything i could think of.thanks in advance
