1 - 6 of 6 Posts
Hi all,
Just installed saddlebags and had to remove rear indicators, looking for where to put them now.
Figured easiest way would be to get a new license plate holder with mounts for indicators and mount bullet turn signals there but lost for which part would fit (based in europe).
Any help will be appreciated!
M. Lineker
Why not just make a unoffending mounting bracket from a piece of strap, extend your wires, and affix it to the license plate bracket. I've seen it done with a few different bikes.
The bags we put on Lady blue's VLX came with a relocation bracket. Basically a strap like @smilie described only powder coated, pre drilled and slotted. Mounted behind the license plate and reroute the wires under the fender with a the tail light loom.
Discussion Starter #4
Yeah will look into just using that method.
Going to have to extend wires than, what type should they be? 18 or 22 gauge?
Discussion Starter #5
So figured out the brackets on the back, gonna use same wire as license plate light since wont be using one.
Looking into led, took the original turn relay out (omron) and want to order led one but connector looks completely different. Any link to a connector for a 3 pin?
1 - 6 of 6 Posts
