moreira72 said:
Just ordered a new rear tire and am going to install myself. SHould come in this week. My question is do i need a special tool to remove the axle. and what is the correct procedure. I am upgrading to a Metzeler 200/70/15 MME 880
You really don't need a special tool to remove the rear tire...other than a good motorcycle jack. I have done it using a floor jack and jack stands, but it does require two people to get the bike on the stands. One to hold the bike steady and the other to position the stands and operate the jack.
Once you have the bike in the air, remove the brake panel support rod and brake connecting rod from the right side of the wheel. I did that at the wheel itself. Then loosen the large nut on the left side. I used a large cresent wrench, but if you have the correct size metric wrench or socket, go for it. Now loosen the pinch bolts on the right side swing arm. Using a rubber mallet, tap the axle from the left to right until it is loose. Now, carefully pull out the axle while supporting the wheel. When the axle clears the right side of the tire, the spacer for the brake panel will fall off. Don't lose this.
Putting it back together is the reverse of above. Make sure that you apply Moly Paste to the splines of the drive side and install the brake panel in the proper position. Once you have the axle nut tightened, tighten the pinch bolts on the swing arm. Also make sure that you properly tension the rear brakes after you insert the connecting rod in the brake arm. Rotating the brake panel will assist in re-installing the connecting rod so leave the support arm till last to connect.
As far as changing out the wheel, make sure your spoons are coated to protect the rim from damage.
Hope this helps.
Joe
