i didn't know whether to start a new thread or go with an old one, but i'm going to take a chance and do a new one.
87 honda shadow
removed the carbs and boots. in the process of removing the carbs, "killed" the top old boots because they were so badly cracked anyway. was able to get "new" used boots from a fellow member.
per the manual, removed the bowl, clean the needles, float valve, checked filter (ok) and cleaned diaphragm and needle.
boiled the boots, put the carbs back on. went to go crank bike (after reattaching appropriate items). in the process, noticed that both carbs are leaking from their bowls, the left one (throttle body side) more so.
1) any advice on how to get the carbs off? it was a pain to put them on, though boiling the boots helped... and since I can't very well boil them again while on...how to?
2) the leaking did eventually stop, since i ceased trying to crank the bike. any ideas on how to determine what from the bowl was leaking? is the gasket supposed to be a perfect fit when you put it back on? (mine wasn't, 90% fit, still screwed the bowl cover back on thinking it would "slide" into place).
yay for bikes!
john
1987 honda shadow vt 700
87 honda shadow
yay for bikes!
john
