Having huge issues with my 1995 honda shadow 1100 ACE
First it died, at medium revs.
Replaced fuel pump
A month later it cracked the fuel pump so I replaced it again
Now heres the problem
When it was running, it would die after about 20 minutes of riding, unless it was kept at low revs. At high revs it would sputter until it got past about 5,000rpm. Then it died completely while cruising after being fine for a few rides.
Fuel runs out of tank fine > fuel line after tank is fine> pump pumps as it should > fuel filter is fine and was replaced a month ago > I took the carbs apart and cleaned it and they seemed fine too.
Whats next to look at? Air filter is clean. I don't think its electrical because it sputters out, and sometimes when sputtering if i drop it to low revs it will stay running, whereas if its electrical it should just cut out?
At times if it is left for a few days it runs alright for a bit, but as soon as its warmed up it dies. Radiator was replaced last year, and doesn't start up before it dies so I don't think its overheating.
have been suggested replacing crank case breather, and rectifier, does this sound like the next place to look?
Replaced fuel pump
