1 - 4 of 4 Posts
One of the screws on top of my master cylinder isn't budging to be able to add more fluid. Any quick solutions as to how to get a stuck screw out before having to replace the whole unit?
Fairly common problem.
You can try tapping on the screw driver with a hammer as you try to turn the screw, or you can try an impact driver. I have had success with both methods, however, breaking the screw off in the housing is always a risk.
For very stubborn screws, I have also had good luck with mildly heating the housing with a propane torch. Be aware this method carries additional risks.
Get your three threads and then you will have access to the technical section where lots or smart techy guys hang out just waiting to help with questions like this.
Before you booger up the screw, grind a bit of the tip off the Phillips screwdriver you're using. These metric cross slot screws are shallower that a standard Phillips screw. Oh, and welcome to the forum!
1 - 4 of 4 Posts
