Hello all,
I just recently came across this group after I got my 1998 Aero. Have put over 600 miles on it in just a couple of rides. Love it. I have one question for those who have been around these bikes longer than I and it may seem vague, but I am thinking if you have personally experienced the problem, you might pass on your knowledge.
There is a ticking noise coming from the engine. It doesn't seem to do this until is warms up, and is intermittant. When I pull in the clutch, it goes away, release the clutch, it comes back. Once it warms up, it will do it at idle, in neutral and in gear. It is loud enough that you can hear it over the engine. Can you recommend anyplaces I should look? The oil is fine, even a little too full. Could this cause the problem? All other fluids are fine. The bike has only 8000 miles on it, so I hope it is nothing too major.
Thanks for any help you guys and gals can impart.
