Here I am again
The Bike began having starting difficulties yesterday, again. Ride fine for 30 minutes, stop, required about 4 attempts to start. Happened after another 30 minute ride. This morning, I put about 1 oz of seafoam in the gas tank. It sat for around 3 hours, and then the bike wouldn't start at all. I could smell gas - although I'm not using any enricher or throttle. I turn the set idle screw back so far it isn't applying any throttle at all - and only then am I able to get it started... but only by listening for the turnover, and then giving it throttle. I've gotten it started about a half dozen times again since then, but only with the same method. Carbs were cleaned synced around 2500 miles ago (in April). While running, I shut off the fuel switch and watched the fuel pump suck the fuel filter down to about 1/2 way, turned it back on and watched if fill back up. Any ideas on what to start digging into to try and get this thing figured out? Oh - plugs are darker than light brown, but not black (all four of them)
